搜索 | 用户支持
详细了解
Mozilla Firefox freezes most of the times when i use Facebook search Bar.
  • 5 个回答
  • 115 人有此问题
  • 8 次查看
  • 最后回复者为 John99
It is last week now that when i use the search bar of Facebook webpage, mozilla freezes most of the times and i have to close it using the task manager. Anyone knows why? I'm running the latest version (28.0) on a Mixrosoft Surface Pro. Intel i5, 4GB RAM, Windows 8.1
所有回复 (5)
Please try Firefox Safe Mode to see if the problem goes away. Firefox Safe Mode is a troubleshooting mode that turns off some settings and disables most add-ons (extensions and themes).
(If you're using an added theme, switch to the Default theme.)
If Firefox is open, you can restart in Firefox Safe Mode from the Help menu by clicking on the Restart with Add-ons Disabled... menu item:
FirefoxSafeMode
If Firefox is not running, you can start Firefox in Safe Mode as follows:
  • On Windows: Hold the Shift key when you open the Firefox desktop or Start menu shortcut.
  • On Mac: Hold the option key while starting Firefox.
  • On Linux: Quit Firefox, go to your Terminal and run firefox -safe-mode
    (you may need to specify the Firefox installation path e.g. /usr/lib/firefox)
Once you get the pop-up, just select "'Start in Safe Mode" Safe Mode Fx 15 - Win
If the issue is not present in Firefox Safe Mode, your problem is probably caused by an extension, and you need to figure out which one. Please follow the Troubleshoot extensions, themes and hardware acceleration issues to solve common Firefox problems article to find the cause.
To exit Firefox Safe Mode, just close Firefox and wait a few seconds before opening Firefox for normal use again.
When you figure out what's causing your issues, please let us know. It might help others with the same problem.
Thank you.
Hello,
Try Firefox Safe Mode to see if the problem goes away. Firefox Safe Mode is a troubleshooting mode that turns off some settings and disables most add-ons (extensions and themes).
FirefoxSafeMode
Thank you.
In addition, if Firefox has been crashing you may have some crash reports that can provide us with additional information.
Please follow the steps below to provide us crash IDs to help us learn more about your crash.
  1. Enter about:crashes in the Firefox address bar and press Enter. A Submitted Crash Reports list will appear, similar to the one shown below.
  2. Copy the 5 most recent Report IDs that start with bp- and paste them into your response here.
SubmittedCrashReports-Win7
Thank you for your help!
More information and further troubleshooting steps can be found in the Troubleshoot Firefox crashes (closing or quitting unexpectedly) article.
If that doesn't work.....
You can try to clear the cache and cookies.
Note: This will temporarily log you out of all sites you're logged in to. To clear cache and cookies do the following:
  1. Go to Firefox > History > Clear recent history or (if no Firefox button is shown) go to Tools > Clear recent history.
  2. Under "Time range to clear", select "Everything".
  3. Now, click the arrow next to Details to toggle the Details list active.
  4. From the details list, check Cache and Cookies and uncheck everything else.
  5. Now click the Clear now button.
Further information can be found in the Clear your cache, history and other personal information in Firefox article.
Did this fix your problems? Please report back to us!
Thank you.
There should be a fix for this in Firefox 29. (Prior to that hopefully the fix will be available next week on the Beta channel.)
For more information please read recent posts in the thread
